the 2 little pipes on the bottom of the rad are the atf pipes.If you only lost a little oil you'll probably be ok.
To refill you will need to fill via the dipstick( the orange one below the fuel filter)Check levels by having the engine running,foot on the brake and work through the gears once engine is up to tempOnce worked through all the gears for a min then check the level
[/IMG]
[/IMG]
[/IMG]
