Hello
I start off like this, I had problems with the water temperature some time ago when I pulled a hanger, I got the answers here I wanted to test the viscose fan. I made and found this was defective. So new ordered and installed. However, since the no ride with a trailer had done more (my mistake it times to test, but had a lot of work). Now we went on vacation, with a caravan and came not far as the engine gets hot. In a Toyota workshop, the thermostat was removed and detected, this is defective, unfortunately the new one has not been there, so they have shut it down (left out). We return to the highway, on the first mountain the engine has become hot again, back into the garage, the water pump, luckily I had my new one yet, (was with in the big package which I had ordered at Rought Trax; 1400 pounds of spare parts). This was built in, but then on the mountain again the same problem, engine hot. (without trailer the engine remains in normal range, on the mountain and at full throttle). So back again. Now I have quickly ordered and installed the cylinder head gasket at Rought Trax, all together cost 1500 euros, and then the test. With trailers the engine gets hot, just as I drive up a mountain, on a straight track it remains normal. Please give me tips on what else I can do. The purse is empty, the holiday is dirty and the car does not do its job.
Thank you and greetings
Martin
Martin
