Hi, having looked at the forum I can see this is a problem that has occurred before so I have already done some analysis anyway here is the summary.
Toyota KZN185 1KZ-TE 3.0 Turbo 1996
Started first time in March, but has stood for about four/five months and now following new battery, will crank but not start.
I have researched on forum and done the following.
Cracked injector, but there is no fuel arriving when engine is cranked. Cracked inlet on top of fuel pump and fuel squirts out when fuel pump primer operated.
Engine starts with 12V direct connection from battery. ECU visually checked.
So the question is what does this tell us. Can I assume that the fuel pump/SPV is not likely to be the problem and that the focus should be on the electrical systems that control the fuel management.
Presumably the approach should be cheapest and easiest first (before jumping to the ECU conclusion) i.e. fuses and relays related to the fuel system should be checked? Which ones specifically?
Any other advice on this problem would be most welcome.
Are there any Surf owners in the Guildford, UK area who would be prepared to lend an ECU for testing?
Cheers, Boris
Cheers, Boris
