Different from a standard Hilux pickup one then? I've never looked it up, just always assumed...
HOT!!! I'm thinking airlock?
Originally posted by Sylux View PostHow did you delete the ATF connections? Utterly pointless for manual owners
How quaint.
Fair point though.
Hopefully the company will stump up the replacement so you don't have to go down the repair route.
A leaky top tank 3.0 rad is on my list of things to acquire..........Eat.Sleep.Surf.Repeat.
Nah, I had to investigate first. Before spending. Now I know and it's cost nothing to find out.
Good job I did as most would have had me taking it to a garage to get the head done
Still, don't want to tempt fate. So touch wood it's a cause and not a symptom
Decided to fix the radiator in situ. Couldn't do a perfectly beautiful job like I could if the radiator was out of the car...but it's decent. Probably better than most.
The solder took well and has sealed the split.
The only one time she overheated was when I didn't notice the expansion tank wasn't letting coolant back into the system (so she was dry (unusual for me) and hopefully no damage happened). Since then I've been transferring over and over and lost no coolant and had no overheating.
Since the fix everything has worked perfectlyExpanded coolant now goes back into the system!
Still no reply from the seller of the radiator, last year, but I'll definitely be getting a new one. Not an ebay one, or Rough Trax's budget one (they're the same and don't last). I'll get one of Rough Trax's premium ones or that alu one from Australia. It's smart looking and looks really well built.
But for now...I'll keep an eye on things and fingers crossed the radiator behaves until I replace (next month when the house sells).
Thanks for all your help, guys
