ps. The pressure is staying even when it cools as there is no coolant drawn back from the expansion tank.
HOT!!! I'm thinking airlock?
Because the rad cap isn't sealing properly creating positive pressure in the rad instead of negative pressure to draw the coolant from the expansion tank.Originally posted by Sylux View Postps. The pressure is staying even when it cools as there is no coolant drawn back from the expansion tank.
Or, you have another leak somewhere in the cooling system.
Just link the two take-off pipes with a section of hose i.e. whete the rear heater pipes tee off from the main coolant pipes.Originally posted by Sylux View Postpps. I'm going to remove the rear heaters from the system.
I'll cut at the engine bay junction, pop a bolt in and jubilee clip them. Sound like the best way? Or U bend the rubber hose :/
For both caps (inc the new one) do this...it's weird? Maybe the rad is wrong at the cap area :/Originally posted by BUSHWHACKER View PostBecause the rad cap isn't sealing properly creating positive pressure in the rad instead of negative pressure to draw the coolant from the expansion tank.
Yeh, after some thought (and some other threads) I was planning on just this. Will be able to use what's thereOriginally posted by BUSHWHACKER View PostJust link the two take-off pipes with a section of hose i.e. where the rear heater pipes tee off from the main coolant pipes.
Yes, I think! They were used to expel heat the time it went to red, last week.
Exhaust should be here in a few mins and I'll do the blanking of the rear heaters. See if anything happens.
Could this just be a daft block, somewhere? Expansion pipe seems clear. It's just not going back in.
Hope so...good to hear anyways.Originally posted by MadScott View PostFargin stumper this, bad head don't stay hard all night...
I'll check all hoses again.
I've fitted the new flexi (canny vibration so see why it's flexi) and took her for a spin. No more loud turbo and runs smooth as. So that's that one nailed.
Surfaces didn't mate perfectly, like. But the gaskets should do their job.
Now I just need to keep an eye on the expansion/no return issue. Can't have two knacked caps, surely.
You could always replace the steel piping with 8mm coolant hose, cheaper and easier.Originally posted by Sylux View PostDeleted the rear heaters from the system. Front and back capped with U bend hose. Back's done just to stop crap getting in.
One less thing to worry about and when I get some cash I'll reinstall using better piping.
http://www.ebay.co.uk/itm/REINFORCED...item19caddabaa
http://www.ebay.co.uk/itm/EPDM-Rubbe...item3f24d09505
http://www.ebay.co.uk/itm/No-8-4-2mm...item53fc277e33
The expansion tank is still filling up and not going back!!! It's ####ing me off!
I took it on another big run yesterday. Horsed it around and no overheating. It's done some canny miles and no overheating issues since the one time it went too high.
Left it till this morning and the expansion tank hasn't gone back in the system!
I've burped it loads so I'm not sure if there could be an airlock.
It has a brand new cap.
I've deleted the rear heaters.
Stuck :/
How does the coolant go back in the system from the expansion tank? I understand how it gets in (pressure pushes the spring on the cap, allowing coolant out)...but how does it get back? If the cap spring closes there's no way back in :/
Help me out, guys
