You starting it tommorow brian ?
AAARGHH! Blown head
 Oh Alan - feel for you there. Same as min. Went on like that for months - then finally gave up the ghost so I had it fixed - an then it went again but thats another story.
 Good luck fixing it
 Oh an I chucked a fancy fix all thing in mine in August before going to go to Santa pod. An it did prolong the inevitable for 4 months.Last edited by Bibs; 15 January 2010, 22:31.How can I be lost when I've got no where to go
 why did it go the second time Viv?Originally posted by Bibs View PostOh Alan - feel for you there. Same as min. Went on like that for months - then finally gave up the ghost so I had it fixed - an then it went again but thats another story.
 Good luck fixing it
 Oh an I chucked a fancy fix all thing in mine in August before going to go to Santa pod. An it did prolong the inevitable for 4 months.Alan
 Because the lovely people at the garage never got the replacemet head skimmed an used old bolts. Didnt even have it 48 hours an poof gone again. So not impressed as you can imagine.Originally posted by KERRSURF View Postwhy did it go the second time Viv? How can I be lost when I've got no where to go How can I be lost when I've got no where to go
 Got a head that had been fitted brand new on a truck only to find it was the bottom end, took straight off, they assumed as it was almost unused it would be fine??? big mistake. Took it back an they got it pressure tested an skimmed an put it back together at their cost. Still have issues though.How can I be lost when I've got no where to go
 Anyone reading Richards post would have been led to believe that using this stuff would lead to an engine seizure, theres drama for you.!!Originally posted by gwh200 View PostThe engine seizure was most definitely caused by using steal seal.
 What has so far failed to be mentioned, is that the fellow in question added it to his engine, not via the cooling system, but straight into the engine, presuming it to be an oil additive. He (rather unsurprisingly) did the bottom end in. It was a classic case of failing to read the instructions.... As it did exactly what it said on the tin.
 BogusСви можемо
 Just to clear things up, I most definatly added the steel seal to the coolant and not the oil ok. At the end of the day, I do know that the heads got to come off for whatever needs repairing, but all the time the stuff working and keeping me on the road, I can now chose the time to have it done. Best of both worlds really. Done nearly a thousand miles with it in now and still running sweet!!
 Its £28 a bottle on Ebay http://cgi.ebay.co.uk/STEEL-SEAL-STE...item1c0f65b222. The cost price to re-sellers is £17.50 a bottle, don't ask me how I knowOriginally posted by busaboy View PostHello
 What happen to you, happened to me last week.
 I bought some stuff called Steel Seal, banged it in the rad like they tell you to, and all the grief has gone. It mixes with antifreeze no prob, but it a`int cheap at £60 a go. Ok, some will say its only a temp repair, but it got me out of the brown stuff, and the trucks back on the road running sweet as you like. Cheers . Whoever you paid £60 to must be splitting his sides with laughter or lighting cigars with £20 notes. . Whoever you paid £60 to must be splitting his sides with laughter or lighting cigars with £20 notes.
 Fair play if its keeping you running though.Last edited by Surfer Ross; 17 January 2010, 01:29.En Ferus Hostis. Be your own man. Follow nobody.
 60 quid would be 2 bottles then, and if I read the blurb correctly you would probably need 2 bottles for a Surf, so I dont think theres any outrageous profiteering going on here.Originally posted by Surfer Ross View PostIts £28 a bottle on Ebay http://cgi.ebay.co.uk/STEEL-SEAL-STE...item1c0f65b222. The cost price to re-sellers is £17.50 a bottle, don't ask me how I know . Whoever you paid £60 to must be splitting his sides with laughter or lighting cigars with £20 notes. . Whoever you paid £60 to must be splitting his sides with laughter or lighting cigars with £20 notes.
 BogusСви можемо
 I never realised it was meant to go into to cooling system as i've never heard of the stuff till matey buggared his engine before.I do apologise if what i put was mis-leading and i will now go and get myself whipped as a punishment..Originally posted by Bogus View PostAnyone reading Richards post would have been led to believe that using this stuff would lead to an engine seizure, theres drama for you.!!
 Bogus   https://www.facebook.com/groups/henpals/ https://www.facebook.com/groups/henpals/
 Richard, so thats your little secret, a bit of flagellationOriginally posted by stormforce View Post.I do apologise if what i put was mis-leading and i will now go and get myself whipped as a punishment..    . If thats the case, then by all means, go ahead. No need to use my post as an excuse. Do whatever makes you happy, as long as its with another consenting adult its fine. No need to justify anything to us on here, . If thats the case, then by all means, go ahead. No need to use my post as an excuse. Do whatever makes you happy, as long as its with another consenting adult its fine. No need to justify anything to us on here,
 BogusСви можемо
 I will go whisper sweat nothings to the wife and see if she will oblige laterOriginally posted by Bogus View PostRichard, so thats your little secret, a bit of flagellation . If thats the case, then by all means, go ahead. No need to use my post as an excuse. Do whatever makes you happy, as long as its with another consenting adult its fine. No need to justify anything to us on here, . If thats the case, then by all means, go ahead. No need to use my post as an excuse. Do whatever makes you happy, as long as its with another consenting adult its fine. No need to justify anything to us on here,
 Bogus
