I had loss of coolant, going into expansion tank and not going back to rad on cool down. New rad, new hoses, everything fine.
Couple of months later loosing coolant, no rise in temp on gauge.
Changed rad cap, system pressurised, lots of white steam coming from exhaust, truck lumpy to start.
Whats the chances of it just being a gasket?
Is roughtrax my best bet to buy new head? I'l do the spanner work myself.
I intend to strip head and get it tested but it don't look to good at the moment.
Anything else I should be doing? Any pitfalls in doing the head?
,im yet to see onne with gasket only,thats sounds similar to when my head went,mine just slowly pushed it out of expansion tank,i could drive 200 miles before topping up,eventually got lumpy start up,if its head i cant reccomend the roughtrax kit enough,but it aint cheap,but they use amc for the head and amc originally supplied the head for toyota,i got the fully built head and its made a massive diffrence to mine,dont even need full throttle anymore,i changed everything,head,water pump,cambelt kit etc,that lot came to a fiver shy of a grand,then my rad went,which was another 200,but if your keeping it well worth it
