well i think i have found out what the rattle is around the turbo.
where the pipe comes out the back or the down pipe for the exhaust i'm not sure as i only had a quick look underneath the surf but there is a bracket under a heat plate and that is all loose and flapping around so i will get that tightened up and see if that is the cure so will let you know later.
thanks for your replies
