Just bought 96N SSR-X Manual from Autoserv at Selby I used to have a bog-standard Brit Forerunner with no frills,my new machine has all the trimmings including those side window thingys 1.How do you stick them back on ?and wot with? 2. my electric aerial has the sound of a manic coffee grinder andhas given up the will to live ,are they expensive and are they easy to fit ?On the whole the truck is a sound unit in a sort of pastel blue with silver grey panels on the doors etc. Does anybody have any tips on underbody treatment ? when I inspected it it was clean as a whistle but the roads of south yorkshire are now 2inches deep in salt n grit. Excellent site by the way !
Niggly problems,aerials and stuff
Wind Deflectors !
Originally posted by nosherHi John, not to sure how you would stick the wind deflectors back on, but you could check out Roughtrax for a new electric aerial, they can sell you the whole thing or just a replacment mast.
Good luck--------Nosher
thanx again mateDeath rides a Black Horse
Schutz ?
Originally posted by KeithI got a logal garage to underseal my 3.0l with schutz. Took five containers and cost about £90.
Thanx for your prompt reply ! you guys are a mine of excellent information !Death rides a Black Horse
Underside Maint.
Originally posted by mickeyjust hose the salt residue off once a week, then when the weather gets warmer, give it a good dose of waxoyl...i'll be doing mine this year, three winters overdue, and its starting to show.
I have a '3 month warranty' with the vehicle' do you think it will be worth owt ?
Thanx againDeath rides a Black Horse
John
welcome to the madhouse - nice to have another Doncaster surfer.
I bought my surf in Thorne (the good garage not the cowboy) and they undersealed (waxoiled) it for me for £85. Apparently it's a bugger of a job in the cold as the wax isn't very runny & it's well messy as well.
Looks just the job and told it should last a couple of years
If you need the number, let me know
ta
hawaiiI'm not overweight, I'm undertall!
no, i didn't get three years out of my waxoyl...cause i never got it doneno, its been running on an untreated chassis, and its beginning to show the ravishes of a uk winter or two...actually, three.
waxoyl is the treatment of choice for most of the pro outfits...you need to have a clean chassis, and mask up the exhaust pipe..keep it away from the brakes too..to have the job done really well, with guarantee will set you back a few hundred quid...but it is thorough..they use a special moisture dispersing spray used in the military for getting the underside of sea harriers clean, and bone dry...then they put black waxoyl on the chassis, and clear in the engine department and behind the doors etc..but it should be good for 5 years..
the waxoyl, and pump spray is available at halfords, you can get some various attatchments for getting it into the box section..personally, i'll be waiting for a warm, and dry day..then tackling it myself..might touch up the tarnish with hammerite first, but it probably won't be neccessary..warm the tin up first, and it should flow just fine..some of the guys on the forum have diluted it with thinners, but i can't recal wether it was considered to be a wise option or not.probably a messy job, but hey..it'll be covered well when i'm done..probably i'll be too..
Originally posted by John hJust bought 96N SSR-X Manual from Autoserv at Selby I used to have a bog-standard Brit Forerunner with no frills,my new machine has all the trimmings including those side window thingys 1.How do you stick them back on ?and wot with? 2. my electric aerial has the sound of a manic coffee grinder andhas given up the will to live ,are they expensive and are they easy to fit ?On the whole the truck is a sound unit in a sort of pastel blue with silver grey panels on the doors etc. Does anybody have any tips on underbody treatment ? when I inspected it it was clean as a whistle but the roads of south yorkshire are now 2inches deep in salt n grit. Excellent site by the way !
will do it again next October,,,chassis is still in mint condition
Martin
Not The Cowboy ?
ta
hawaii
I think I may have seen your Surf over at Barnby Dun, Does that mean mine is glacier Blue then ?it is a very light blue over silver I have put a s/steel rear tyre cover on ,just waiting for a quote on someone painting the disc with some aviation 'nose art' on it
(it has an indian chief on at the moment ,got it from 4x4 at Leeming)Death rides a Black Horse
Roghtrax !
You are a life saver, Roughtrax is an excellent site !even have full kit in stock !The wife is after my blood I got rid of a Mazda B2500 D/CAB with all the trimmings 2.5 years old and still only 35k on the clock ! now if anything goes wrong with my beloved Surf then its ' told you this would happen' blah blah ! anyway thanx mateDeath rides a Black Horse
John
now let's no beat around the bush (or tree) here's a clue
A key will usually open something or somewhere you want to be and be happy
A tree is was lynch mobs used to hang people from (sometimes innocent ones)
If I'm being too crypic then Tree =
and Key =
just my opinion tho (call of the lawyers)
ta
Excellent choice
and Key =
ta
hawaii
The wife got an excellent nissan deal from Fraser, they know their stuff pity they didn't hav some manual stock then I wouldn't have had to trek to Selby!Death rides a Black Horse
