Just try the M60....this is a nightmare in the mornings.....nothing but stop/start.
Yay!!! - 30mpg
thats appaling - your first tank!!! you must have been scared of the size of somethingsoon enough it will come down!
I get about 300-350 per tank, had 470 out of it before top to bottom but I also did 160km on £30 tooAHEM!
Tim
Originally posted by miketilleyHehehe....well since discovering how to turn the overdrive off and realising how high the volume goes I suspect my second tank will not be so good.....I can see that LR fading already....
Tim
I notice the difference with the fuels too :-)
Esso gives best power, Total gives the best fuel economy but the power is down, BP sounds different to Texaco but both of them give good power and reasonable economy - 400km from brim to warning light. In my experience anyway
I do a mix of driving usually with about 200kg of tools and stuff in the back. When I don't I tend to have the boot down so I will never see the illusive 30mpg
Edit: Oh and supermarket fuels tend to make it smoke like a chimney!
Rich.If life's an uphill struggle then downhill from now on can't be that bad?!
Originally posted by ChasesDragonsI am getting a consistant 510 or 520 warning light to brimful. what is that? about 28mpg? I am running Biopower's biodiesel most of the time (60:40 mix in dino diesel's favour)....
Udhi
How much do you put in Udhi?
So how much fuel is left when the light comes on, and where is the guage reading when it comes on? I've never seen mine come on and have run it below the lower mark on the gauge.
I managed about 450k on a tank the other day (day after boxing day), before bottling out and filling up again. Suspect it would have been better if the M6 wasn't varying between stopped and 30mph.Cutting steps in the roof of the world
