Ok after much thought, and cash, I have decided to sell my surf. The problem is I don't know how much is worth. It failed its MOT last month on a fuel pump leak only. My mechanic says that because its an import he cannot source the seal I need, so he cannot repair it. I cannot afford to spend another £150 on it just to be told it cannot be fixed. It starts and drives and everything that should work does, even the bumpers have been replaced. If I had the space to strip it I would because I know all the parts are worth money but I would rather someone had it and made use of a good condition truck. So im looking for a reasonable price to stick it on ebay for but I have no clue as to the value and know that someone on here will know its value. Thx in advance ppl.
Price
Originally posted by rickus View PostOk after much thought, and cash, I have decided to sell my surf. The problem is I don't know how much is worth. It failed its MOT last month on a fuel pump leak only. My mechanic says that because its an import he cannot source the seal I need, so he cannot repair it. I cannot afford to spend another £150 on it just to be told it cannot be fixed. It starts and drives and everything that should work does, even the bumpers have been replaced. If I had the space to strip it I would because I know all the parts are worth money but I would rather someone had it and made use of a good condition truck. So im looking for a reasonable price to stick it on ebay for but I have no clue as to the value and know that someone on here will know its value. Thx in advance ppl.
13+ Years of Surfs ..... n Faultless to a "T" is my Yota !!Buncefield Burner
I have the one from roughtrax for the denso pump but it's not that seal so it seems. I have been told that my pump does not match any of the 3 that are listed for hilux surfs, it looks like an espada or something but the part numbers don't tally up. There are upmps on eBay but I have no numbers to go by, the I'd plate is corroded and pitted so is unreadable. So I'm not sure which pump I would need to get. I have looked into any away not to have to sell it but I'm pretty much out of options I think. I should also mention that it's a 1991, j plate, 2.4 auto, ln130.
cant fid any seals on milner, my mechanic said he has called a local diesel specialist and hey can look at if I get the pump off but he cannot get the crank nut undone? ( not sure what that would do). So, there being 3 different pumps for my truck and mine not looking like any of them im at a bit of a roadblock. Only thing he said was to maybe re-engine it, which I cannot afford after being outta work for 2 years cos of bloody throat cancer. That is the only reason im selling, I would love to keep the truck, ive owned it for 4 yrs and love it to bits but im stuck now.
£500 if you want rid
Which is a waste of your money for about an hours work and £20 worth of o rings.
The fact that your so called mechanic can't ; one source the parts and ; two can't undo a crank bolt beggars belief.
The quick and dirty bodge would be to fire some brake fluid into the fuel tank and let that swell the o rings and and least then sell it with an MOT and as long as the new owner knows the seals might need changing then you can sell it with a clear conscience.
Like Woodwarm said bribe someone with tea/biscuits/bacon/beer don't break it just because of an o ringEat.Sleep.Surf.Repeat.
I don't know what o ring to get, and my mechanic has phoned local Toyota dealer and without knowing what pump I have he has know way of getting a pump seal kit. The one you are talking about from roughtrax costs approx £40 which I purchased straight away and he has fitted them to be on the safe side. There doesn't seem to be any other seal kits available. Tbh I even looked into a new pump and they are £2300 if they can get one which the dealer said was probably a no because of the age of the vehicle. So it's not really a couple of hours work and £20, I would be having that done if I could. That's why I came asking a price because this repair is probably going to cost another £300 the way it's going. A local diesel pump repair place said they could look at it on the bench but would not confirm whether they would still be able to fix it. I can't afford to replace the truck but I also cannot afford to pay any more money.
Originally posted by shokenore View PostWhere is the fuel leaking from?
Got any pictures?
Sometimes best to sell & save further worries.
Seen similar on ebay (running with faults,no mot) £700 on a very good day.
On a bad day £200 ish
