Off the scale!
After a nice period of trouble free motoring (apart from the leak) I got another increase in temperature this time going north on the M1 to Sheffield.
On this occasion I never exceeded 70mph, the weather was hot, I tried to keep the turbo light off as much as possible.
I have taken on board all comments and thoughts mentioned previously and thank you all but one thing I have noticed is heat inside the cab near the footwell. Is this normal?
This I figure is the auto gearbox? I've checked the fluid level for this and it reads fine but how is the gearbox supposed to be cooled? I read the radiator cools the fluid somehow but I didn't get itLeaky Surf
Cheers Vince. I see, do these pipes convey engine coolant to the transmission or atf to the radiator and if the latter is there some sort of separate core in the radiator?
Also while on the subject of transmission cooling how do the separate cooling things work that I've heard of.
Thanks againLeaky Surf
Been a while but still have no heater heat.
Just had the water pump replaced on the presumption that it may have been a slipping plastic impeller which I thought made sense ie it spins enough when normal driving but not enough under load or to push hot water through the heater matrix.
Needless to say I was very happy to discover that a) the old pump was all metal and fine b) I still have a luke-warm heater c) I paid good money for the new water pump and garage time.
So while cruising these pages to find details of the last resort plan of replacing the heater matrix (which I know is a massive ball ache) I had a thought which I would like your thoughts on.
I have already had the system flushed and I presonally have flushed/back flushed the heater matrix too but figure there could be crud still in there preventing heat. My idea is to hook up a wet/dry vacuum cleaner to the in-situ matrix and try and suck the s*** out of it, adding water through the other hose as required.
Is this any good? Anyone else (daft enough) to have done this? Am I wasting my time?
Opinions always welcome.Leaky Surf
Hi Rob,
Funny you should mention that but not long after I posted this I read a thread mentioning this.
I presumed that when you move the lever to hot on the controller it just opened the valve on the inlet pipe in the engine bay (which I know it does), but didn't realise there was a flap it opened as well.
I shall inspect this flap before I try any hoovering
BTW, do I have to dismantle anything to get at this flap?Leaky Surf
the hot / cold selecter on the heater controls does go direct to the heater valve on the bulkhead.
The buttons above the hot/cold lever control a cable that moves the various flaps in the heater ducting to control where the hot air goes.
Originally posted by wishbone View Postthe hot / cold selecter on the heater controls does go direct to the heater valve on the bulkhead.
Nev.
