driving back from Sheffield on the M1 between Jnc 28 and 27 southbound the temperature needle went off the scale. I was admittedly going up hill at 80 (which I have done loads of times) but surely with a new stat and coolant with a higher boiling point this should never happen?
I had a new thermostat and the system filled with Toyota red coolant after having had the system chemically flushed by a local garage only yesterday!
Prior to this for about a month I had been running on just tap water with a new radiator cap, with no issues, after having tried to flush the system myself (was 90% success except I couldn't do the big hose at the bottom of the radiator).
Any ideas?
I am due to travel on holiday on Saturday and this is not what I wanted to see.
By the way, after leaving the motorway (luckily jnc 27 is my exit anyway), I drove carefully and the needle started to drop, being at normal about 5 minutes after.
Any ideas?
