From what you've said, the primer sounds knackered since it doesn't pump diesel through, but you can suck it through. As i mentioned, I had a similar issue and mine runs fine with a broken primer. AFAIK they are only used for getting airlocks out of the filter after changing it, or if you run out of fuel. Have you tried checking if fuel is getting to the injectors? When I sucked the fuel through manually, a good few cranks got mine started and has ran fine since, although I'm very careful to not run low on fuel now
