Egr removal
  • #61
    spec savers
    See here
    ah know should went ta but can't find the place
    • #62
      earth to manifold
      Originally posted by flounderbout View Post
      Have you tried this?
      try'd on manifold na starto and to chassis still know start that was wk ago before starter packed in but tomorrow another day try putting them back on block see what happens but with ignition on showing 6.8 volts so how that if or guy's saying they're earth
      • #63
        Frank, you do know there is only one fuel line on your fuel filter don't you?
        it's in me shed, mate.
        • #64
          See here
          • #65
            Is that where the wires go?
            • #66
              See here
              You owe me a laptop due to tea spitage....
              What have I told you about thinking Erroll
              • #67
                I could spend hours reading the drivel on there. Oh wait, thats what this thread is for!
                Honest guv, it came up with this...
                "Why does the willing mass cough her diesel?"
                Non consternationes.
                • #68
                  Can't find 173 fairly st, the guys in J F Autos have also never heard of it and they are on the corner of Woodville and Fairley st.
                  Brian
                  • #69
                    Originally posted by frankx View Post
                    30 amp fuse 30 amp relay to button from ign. switch one first things i checked on the list glow plugs took them all out . regarding 2 wires. got me baffeld. i post few pics of layout egr removed 2 wires in photo location as where they go? still miserty
                    If you have a manual glow system then that may explain the disconnected wires. Not needed now, so someone disconnected them from the resistor. Have you had a look to see if the resistor is there and has any wires connected to it. Not convinced they are earth wires but may be wrong.
                    Nev
                    • #70
                      still no go on block head earth
                      hi guy's tyred that wire on bottom starter bracket witch is engine block earth also have earth running staight from batterie neg. earth to bulk head still no go took another pic of that wire tested again with ign. on reg. 5.10 volts as you can see in pic. heavey padding on the core loom definately not earth address 174 woodville street sorry mate my mistake big iron gates in between fraser mac donalds and protors garage amg tyres just ask for alec murty's place if you let me know what time your comming at?. i'll stand out in street what car are ye driving?
                      • #71
                        glow plug resistor
                        Nev
                        i it still has two wiree connected to it top and bottom looks untouched
                        • #72
                          right location
                          [QUOTE=yoshie;743601]Can't find 173 fairly st, the guys in J F Autos have also never heard of it and they are on the corner of Woodville and Fairley
                          • #73
                            am ben right place mustben wrong time
                            sorry yoshi frank here my mistake thousand appolgees 174 woodville street in between fraser mac donalds and protors mot station alec murty's amg tyres
                            • #74
                              Wil it start if you give it a squirt of easy start/carb cleaner or brake cleaner whilst cranking the engine?...might be all it needs....maybe...
                              • #75
                                try'd that
                                took hole can nothing something electrical?
