I'd been worried about getting the crank pulley off, so I made up a tool. Worked really well and undid easily
I noticed a bit of damage on the harmonic balancer - is this ok or is it time for a new one?
The plastic cover has been worn away a bit too. Again, is this ok or is it time for a new one?
There are holes for 3 bolts to hold the plastic cover around the water pump, but no bolts were fitted. Is this normal?
Found a few other problems too. I noticed a bit of play in the power steering pump and traced it to the pivot bolt. Took it out and it was well worn - M10 worn down to 8mm in places!
The alternator tensioner screw had seen better days, so I cobbled together a new one.
I'm replacing all the usual timing belt stuff plus the water pump and crank/cam oil seals. Is there anything else I should check/replace while I've got it in bits?
Dan
Dan
