I'm in the process of replacing my LN130 head, so I reckon now would be the time to lose the EGR kit in total & blank off the ports. However this may be mechanically simple but is there any other work involved other than blanking off the vac pipe. No doubt this has been gone thru already, but an up to date answer may be better, what are the long term effects etc. Ta.
Egr
Originally posted by craigH View PostHas anyone removed the whole lot like in the link?
Ive cable tied off one of the pipes so far for about a year but like the idea of getting rid of what I dont use - worth doing?
Originally posted by craigH View PostHas anyone removed the whole lot like in the link? Ive cable tied off one of the pipes so far for about a year but like the idea of getting rid of what I dont use - worth doing?Do you know that, with a 50 character limit, it's
Originally posted by Bazza52 View PostI guess the central heating plumbing in pic3 is to bleed the cooling system.
Excelent link, thanks for the replies just kicking myself I didnt do it a few weeks ago when I changed my head, Im going to do this mod on the weekend but doing it on the bench would be so much easier, I say you got it the right way round Bazza - any extra room in the engine bay is a bonus! Thinking of removing the air con next, never use that either
Originally posted by Bazza52 View PostMust of cost a bomb in BrassoWell worth fitting one if you're contemplating it, rather than giving it a miss. You might never use it, but it always there if you need to. There is also the original design that mine was based on which just has a bleed valve. This is the other type:
Can't remember who did that one originally, but it was another member on here. Personally, I'd suggest the former of the two. Couple of things I would suggest if you make one, btw.
1) Solder a ground wire to the unit and make sure you ground it well.
2) Those brass olives. Get a compression blanking plug for capping pipes and use that to ever so slightly compress them before you pop them on and solder them up. You only need a slight nip on them. It's just to remove the play in them and make them a good, solid fit. Plumbing fittings tend to be a loose fit as supplied, (which is why those olives look slightly skewed on that pic above). I never used that method with the first unit, but did with the double unit.
Thanks for that Matt, have got the bits to do the head now apart from more shims, will pop into main stealer for them then call at B&Q for the plumbing bits. Just found a lapping kit on ebay for £3.75 as mine was getting tatty. Will I be up and running before xmas? I bl%$dy hope so, but depends on weather.
Originally posted by Albannach View PostUsing the cable tie method is pointless if the EGR is stuck open?
Surf K Reg LN130 2.4 AUTO
