Egr
  • #16
    Originally posted by nigel129 View Post
    How do you tell if the valve is stuck open ?
    You'll notice no change whatsoever when you disconnect the vac pipe.
    I disconnected a small pipe at the rear of the engine bay as recommended by another member, is that sufficient if the valve is/was working.
    Yes.
    • #17
      so i should go for the full blanking off method then ?
      nigel
      Surf K Reg LN130 2.4 AUTO
      • #18
        so i should go for the full blanking off method then?
        My psychic abilities are a bit shagged today.
        • #19
          nigel
          I would, he one on my 2.4 was stuck open.
