thanks mate somthing to be going on with will take a quick look in a sec and let you know
if the switch has burnt out im assuming i can rewire using new relay and switch or will this just engage disenged the clutch
ta
ok jumpered the compressor and the clutch engages left running for 10 minutes still luck warm air cant see much in the little window
im now assuming it just needs regasing after i have rewired the switch i have a relay and switch thinking of just running new switch for now any ideas for a wiring diagram i am pretty handy and have a pretty good understanding but cant afford to damage anything
i cant find any labels as to waht gas is in there is there any other way of telling
heres the diagnostics thus far
with engine running if i press the A/C switch on the dash the A/C fan under the engine spins up but not clutch
with engine running if i press the A/C switch on the dash the A/C fan under the engine spins up and clutch when jumpered from battery (assume this could be due to low gas "safetey switch" so will i have to regas first or can this be bypassed fro short burst just to ensure both clutch and fan spin up when a/c switch pressed
still warm
so the way i see it i have 2 problems somthing isnt fireing from the switch to engage cluth (relay/fuse) all fuses in the engine bay seem ok
not sure if i can hear any relay click when pressing a/c switch
so firstly any ideas on how or where to start looking for electrical fault for clutch as once i have sorted this ie press the a/c button fan and clutch spin up i will then get the system pressure tested and regased and fingers crossed problem solved
i know its saturday night and you all probably have somthjing better to do but any help is much appreciated
thanks for all your help so far
ta
still warm
