A tired mechanic looking for all and any help!!!!2.4 TDi, 1993 model, came to us with new water pump & no apparant problems!!!
Drove it 30 miles before gauge jumped and steam came out, got it trailered back. Stripped off head - no apparant external damage/cracks. Did'nt bother with pressure test bought new uprated head, gaskets etc etc etc.
Bled the system, changed the cap, new heater plugs, viscus fan working ok, 50% anti-f mix. Run it in situ for 1 .5 hours to bleed - seemed ok - all hoses hot. Drove it 10 mins boiled like a kettle. took it back, fitted new copper radiator, bled again for 1 hour, took for 10 min drive - BOILED again - system sucked back coolant from overflow tank when cool so cap is ok. Took 1 litre coolant when cold. Did the coloured sniffer test - no problems showing. Bought another new cap, & removed the thermo anyway. 10 min drive - BOILED again!!!!
Gave it another sniffer test - NO problems showing!!! No oil in water or vice versa etc. When it boils & the overlow pipe is left out it steams like a chimney - put it into the tank and it boils/bubbles like vesuvius!
I know there is a possibility that the water jacket is fractured but surely the would be cross contamination???
When cold - run engine 2 mins max - remove cap and pressure is apparant!!
H E L P - 30 years experience, £900 spent on parts, and I am stumped!!!!
