Primer Pump Duff...Help
  • Primer Pump Duff...Help
    Replaced the Diesel pump filter but the ****** thing wont prime.
    Done the operation exactly to manual instructions.
    My Questions are.
    1, Is this hand Pump Serviceable?
    2, If NO where can I get a nice cheap one from?
    3, Is there a work round for this problem?
    4, Will I have to crack open the injectors to further bleed the sytem on this year model?
    The Surf is a 91-H in the year and is the 2.4td Auto.
    my personal e-mail at [email protected]
    Thanks in advance my fellow 4x4 Surfers from Peter
    My Questions are.
    2, If NO where can I get a nice chep one?
    4, Will i have to crack the injector system to further bleed the sytem?
    you dont need it, fill the filter with diesel before you fit it, crack open an injector, turn it over to bleed
    [size=5][/size]
      Keep trying, I had to pump mine for absolutely ages !!! around 5 mins I think.
      Andy
        Andy
        a quick check to test it is, take the pipe off the pump head coming up from the tank and put your finger over the hole to see if its sucking as you pump it
        [size=5][/size]
          1993 Surf Auto
          Dear All
          Just a quick question! I am just about to purchase a 1993 2.4 Diesel Auto SSRX Surf Jap Import. Can some tell if these models are full time 4x4? Or is it selectable 4x4..
          is there anything else to look out for?
          I have read about the Head thing etc
          Thanks
          Brett
            Originally posted by brettb
            Dear All
            Just a quick question! I am just about to purchase a 1993 2.4 Diesel SSRX Surf Jap Import. Can some tell if these models are full time 4x4? Or is it selectable 4x4..
            Thanks
            Brett
            selectable 4x4.. but not for use in 4wd on tarmac, only loose surfaces
            [size=5][/size]
              Excuse my ignorance.. So the high and low lever next to the gear selecter is the 4x4 selection?
                no, there is a button on the side of the lever, when you press it 4wd will light up on the dash, when you select low it goes into 4wd automatic
                [size=5][/size]
                  Right i see so how is the best way to check this is all working?
                    over to jim
                    i thought you was going to answer his question
                    [size=5][/size]
                      over to jim
                      i know where you coming from put your post back
                      [size=5][/size]
                        over to jim
                        i thought you was going to answer his question what do you mean jim
                        dont mind me I'm only ribbing, that post is deleted, all the same Ian you said selecting low on the lever means it goes into 4wd automatically. I understood selecting low applied in 2wd and 4wd, and only when the button had been pressed did it engage the front.
                        and seen as its over to me :
                        lever in hi: normal driving
                        lever in lo: off road driving where steep ascents are involved
                        4wd button pressed: all of the above except now in 4wd
                          Right i am totally confused now. The guy i am buying it from says the car is full time 4x4 ?
                          So there is a select button somewhere?
                            jeez you got digital attention there Iano, dont miss much do ya
                            :took a while though:
                              no you dont need to press the button in low
                              [size=5][/size]
