ok, so since i had my free flow exhaust done the boost keeps going up to 14psi. when i notice this on the gauge i immediately let off so i dont risk any damage.
the previous owner had done the actuator washer mod with 3 washers on each bolt and he had also fitted a bleed valve type thingy.
the bleed valve has 2 hoses on it. one goes on to the turbo (i think this hose sees the current boost pressure) this connects to the brass valve with a screw on it to adjust the boost pressure, and another hose goes on to the actuator.
i was told to wind this valve all the way in to lower the boost pressure and then gradually wind it out bit by bit and drive the car to see how it goes. so i wound it all the way in from where it was (about half a turn) and i still over boost to 14psi
so i decided to take the washers out of the acutator. i took 2 out of each side. it hasnt made any difference, i still get to 14psi.
ive done a search of the forum and havnt found anything i could use..
so i thought may be my valve is backward, so i wound it out to half way and its still the same.- 14psi.
i cant put my foot to the floor or else the boost goes too high, and if i dont back off quickly then the red light comes on. im supposed to be going off road this weekend and wont be able to if i dont get this sorted, and i wont be able to drive on the motorway either!
someone?
im not even sure the valve is wired up to the right place
someone?
