OK, Cam belt should be here for the weekend, i got the aus download but are there any other hints/tips i might need to know before i get going, looks straight forward and i've done em on other cars, but always weary of these surfs, everythings out the way so it's all clear to get at, cheers
Cam belt
Originally posted by ian619OK, Cam belt should be here for the weekend, i got the aus download but are there any other hints/tips i might need to know before i get going, looks straight forward and i've done em on other cars, but always weary of these surfs, everythings out the way so it's all clear to get at, cheers
Line all the marks up, cam pulley mark points straight down, the crank and fuel pump pulley point straight up.
Loosen the nut in the centre of the tensioner roller and lever it to the left and tighten bolt to hold it.
Fit belt, but turn the crank sprocket two teeth anti-clockwise.
You'll see why when you release the tensioner and rotate the engine a couple of times, the crank sprocket will be a tooth or two out (too far advanced) fitting the belt with the sprocket two teeth before the timing mark allows for this.
Originally posted by BUSHWHACKERLine all the marks up, cam pulley mark points straight down, the crank and fuel pump pulley point straight up.
You'll see why when you release the tensioner and rotate the engine a couple of times, the crank sprocket will be a tooth or two out (too far advanced) fitting the belt with the sprocket two teeth before the timing mark allows for this.Too young to die and too old to give a toss
Originally posted by MattFAlso, make sure you don't do Charlie's trick and get it 180 degrees out.
Oopps, i had my tea while doing that post and could'nt remember if i clicked submitThere's no **** like an old **** eh!
are you jokeing, did he do that? is it possible to do that? if so ya can bet i'll do it,
Hey Matt! just going to have a good read through your famous viscous fan thread, on Bushwackers mod, figured i'd do it while it's off, thought of printing it all and haveing a read in the bog (do most of me reading in there, fag, cup of tea and a good book, ahhh heaven)Last edited by POPEYE; 17 May 2007, 18:26.Too young to die and too old to give a toss
Originally posted by ian619are you jokeing, did he do that? is it possible to do that? if so ya can bet i'll do it,Apparently it ran, but sounded like a bag of spanners.
Originally posted by ian619Hey Matt! just going to have a good read through your famous viscous fan thread, on Bushwackers mod, figured i'd do it while it's off, thought of printing it all and haveing a read in the bog (do most of me reading in there, fag, cup of tea and a good book, ahhh heaven)
Originally posted by MattFYup. When he did Ferret's Surf.Apparently it ran, but sounded like a bag of spanners.
So how'd he do it (or should i ask him) did he have the marks arse about face
Make sure you have a good supply of paper in the printer.Too young to die and too old to give a toss
Take the radiator out - it'll be much, much harder with it in. Only a few bolts to take out - well worth the effort.
Loosen the bottom pulley bolt using the starter motor trick.
Clench buttocks tightly when restarting the car.
I took a liesurely 3 hours or so - take your time and you'll be fine.
Good luckAnother member of the 'A' team
Its a peice of **** mate, i never done the turn a crank thingy, i never have had to do that on any car. The only thing i ever move is the cam if its being a sod? But these folk have done loads, i have only done one surf belt/What comes around goes around!!
Originally posted by ian619Cheers mate, yeah thats probably why the aus guy said it's a bit os a sod as it keeps jumping a tooth when ya let the tensioner go.
Nev
Originally posted by Terry SydCould someone give me a link to the 'viscous fan mod' that was referred to earlier?
Thanks
http://hiluxsurf.co.uk/forums/showth...=disassembling
Hope you have lots of spare time!
Originally posted by The Lovely BoyoTake the radiator out - it'll be much, much harder with it in. Only a few bolts to take out - well worth the effort.
Good luck
probably would have launched the spanner or stuffed the starter, i made a locking bar up after removeing the outer pullys, i was wondering how charlie got it 180% out thoToo young to die and too old to give a toss
