Knocking on Heaven's Door?
  • #61
    Originally posted by plumb bob
    It'll be a pig to start first thing, and be lumpy till it warms up.
    He's p1ss taking. He's referring to the air filter.
    • #62
      Originally posted by Ravenelli69
      Just as a matter of interest, what causes the knocking sound coming from the engine?
      That cylinder isn't firing, because the injector isn't working, or working very badly at best.
      • #63
        Oh yeah, he he , I'm a bit slow tonight.
        Rob
        Still working for the man!
        • #64
          Cost of each injector?
          • #65
            Can't find anything on milners or roughtrax, so you may have to go to toyota main dealer, you will need to give then engine and chassis no's for their database, but then thy can locate your specific vehicle and tell you which factory it came from,
            Rob
            • #66
              Will do, thanks again!
              Geoff
              • #67
                not sure but mine need doing soon, i got quoted £80 by eurocarparts, but i reckon i can get them a fair bit cheaper. Other option is to remove and take them to a specialist for re-conditioning. I'm not sure if milners or roughtrax do them, or TonyN on here can probably get them.
                =SOLD UP!=
                • #68
                  Geoff
                  No worries, hope you get it all sortd out soon, keep us posted.
                  Rob
                  • #69
                    bottom middle on hee possibly but hopefully someone will be here soon that knows. http://www.fiveomotorsport.com/Injector_SetsTOY.asp
                    or http://www.uniteddiesel.co.uk/diesel_injectors/toyota
                    again check these are the right ones.
                    =SOLD UP!=
                    • #70
                      fantastic thread!
                      good trouble shooting guys!
                      Landcruiser Colorado
                      Sub. Forester
                      • #71
                        Sounds like if I tried to do some work on an engine. Dad, is that you?
                        If replacing glowplugs and/or the fuse, I would strongly recommend disconnecting the batteries first. Going on the above, we probably want to avoid a thread along the lines of 'arms blown off by electric shock, am I in trouble?'
                        • #72
                          You forgot to tell him where the batteries are.
                          • #73
                            Give Diesel bob a ring, he services all my injectors, you need a 22mm socket to get the bottom half of the injector out, stick it all in a bag along with the other 3 injectors (use a 22mm socket to get them out, or you'll leave half behind again)
                            Full set of recon injectors will cost approx £150.
                            http://www.dieselbob.co.uk/
                            And get a workshop manual next time!!
                            • #74
                              This thread has made my day thank guys
                              • #75
                                Top thread this, Still at least i now know what size sockets i'll need when i do
                                mine
