All,
Had a go at changing the spark plugs today on my 1993 Hilux, and typically have ended up in a mess. The first thing I did was remove the bar that goes across the top of where I think the spark plugs are located. Then I set about removing the 1st bolt (which I slide back across the connecting bar)
and then the 2nd bolt. Once this was done I got a 19mm deep socket to remove what I thought was the spark plug - it goes into the engine at an angle. When I took this out a spring (I checked it was a spring by opening the one beside it to make sure I wasn't imagining things) fell into the engine never to be seen again! I put everything back (minus the spring) and started it up. Now I have a knocking sound coming from the engine!
Was I even working on the spark plugs, if not, what was I working on?
Pieces I took off looked nothing like the plugs I got from the auto shop)
Any advice greatly appreciated
Geoff
Geoff
If not, his Missus ought to confiscate his tools.
