Hi all...
recently fitted a new 2.4TD recon unit with gearbox and its not performing...at first i thought vacumm pipes but with some help from you guys they are all now spot on (i also varified with another truck with the same engine..just to make sure!)
then thought the problem might be caused by the 35" muds id just fitted...so to elmiminate i put the originals back on..and no improvment...still struggle to get out of 3rd gear and anything past 50mph on the speedo (actually im now traveling slower..due the smaller wheels according to GPS)
i am intermitantly getting the engine light on (and the turbo light goes off) done the diags..and getting 2,12 and 13....the 2 i can understand as i found oil in the turbo vacuum pipe to the sensor...
any ideas on the 12 and 13?...the fuel pump has been replaced during the engine fitment (assuming with a good one...but not recon etc)
another thing i noticed..on startup it seems to take quite a lot of turns before it fires...and once it does fire...it splutters and coughs a bit (sounds like its missing) before ticking over fine...revs up fine...just doesnt seem to be able to cope once you load it.
it has had a new set of glow plugs BTW...
coudl it be this fuel pump if dead?...i was gonna order the Milners seal kit and see if that makes any improvment...
it does seem to be using hell of a lot of fuel too...(im sure its single figure MPG!) but that might just be due to the fact the accelorator is always burried in the floor in the hope of some more power!
Wish id put the V8 in it now :P
