i finally got fed up with my on going overheating problem so i decided to just change the engine.
After ringing round a few breakers yards i was offered a 2LT engine and was assured it was exactly the same, and all i would have to do was change round the injector pump, inlet and outlet manifold, etc.
so i took my engine out this morning. After checking both engines i have found that mine has a crankshaft sensor and the 2LT engine does not.
if i go ahead and fit this engine after swapping everything around will this run without a sensor, or will i be left in even more problems like engine management light etc.
would my best option be to leave the engine back.
Has any body and advice or ideas
in the same direction as ours..........ha ha
