i finally got fed up with my on going overheating problem so i decided to just change the engine.
After ringing round a few breakers yards i was offered a 2LT engine and was assured it was exactly the same, and all i would have to do was change round the injector pump, inlet and outlet manifold, etc.
so i took my engine out this morning. After checking both engines i have found that mine has a crankshaft sensor and the 2LT engine does not.
if i go ahead and fit this engine after swapping everything around will this run without a sensor, or will i be left in even more problems like engine management light etc.
would my best option be to leave the engine back.
Has any body and advice or ideas
