Crankshaft Position Sensor.DO I FIT NEW??
Big Thanks to Rubble bags & Steveo,
Just back fromToyota & it looks like the kiddy 'cos it has the retaining bolt, however, no sign of an "O" ring??
Well is it worth a shot for £40? I suspect if the gap? (yes I'm guessing here!)
between the sensor head/pickup is worn then it could be sending duff info to the pump & the ECU? as I've tried everything else other than replacing the ECU itself ,my only other chance is setting the pump to the 2L non-turbo non-EFI.Settings? What do you think guys???
Gary.
Gary.
