Egr.
Thanks Fella's,
Blimey, I've spent an hour reading up on this, hmmm!
Well I've a confession to make, I did notice the EGR vacumm pipes had become very loose whilst putting it all back together and changed them for some nice tight fitting non-standard jobbies BEFORE I started her, after fitting the pump and t/belt. Is it worth disconnecting this to see if she runs better? I only really want to eliminate the Diesel knock at this stage? N/B After I flushed out the runnning-in oil I noticed the new oil got very sotty quickly! (before my problem) Could this be the Pump timing or the EGR was working properly?
Where to you put the blanking of bolt? No thoughts on Pump timing?
Gary.
Thanks Fella's,
Gary.
