Hi guys,
Been towing a lot lately and as a result the clutch seems to be slipping on the surf now.
You really only notice at about 3k rpm in 4th, then it seems to be ok.
It still seems to pull fine going up hills. But you notice it mainly on motorways and stuff, pulling on from the sliproad by the time you reach the motorway it slipping.
Is this an expensive fix, and can clutchs be adjusted or is terminal if it starts slipping?
Thanks
Thanks
