Outer track rod end
Originally posted by BUSHWHACKERTo be honest, I've never even looked at my rod ends, They passed the MOT so they must be o.k. I try not to go looking for things to repair, as it normally means £££. Preventative maintenance is my method.https://www.facebook.com/groups/henpals/
Originally posted by stormforce1067i dont normally look either but i had a call from the dealer after the recall and thats when i noticed they split the rubbers and left 2 bolts out of the bash plate
Got the bugger out. Only two hours.Leaving it till the morning to put the new
one on, but at least the hard bits done now.Cheers for all the advice and
help.
Ended up with a long ring spanner over the end of the threaded wheel joint, and
feet against the tyre to get enough oomph behind it to get it moving. Are they
tough to get moving.There is quite a bit of play in the joint on the old one. At
least I know she'll pass her MOT now.Thanks once again.
help.
Originally posted by stormforce1067water and muck works it way into the threads and just seizes them up the only way to prevent them seizing would be to lag grease all over the adjuster to stop $$$$ getting to the thread
it in, then the tube'll be getting some waxoyl, so hopefully that will also creep into
the threads, just incase I ever need to replace the inner.At least I didn't have
to get the blowlamp on it. With the amount of waxoyl I've caked over the chassis,
that was one blessing.
Originally posted by MattFI'll be chucking some copper slip/ease on the threads of the new rod when I put
that was one blessing.https://www.facebook.com/groups/henpals/
Originally posted by stormforce1067i got to slap some grease on mine yet come to think of it.will do it on tuesday when i go into work.I'll use some grease what we use on the railway its really good thick stuff so it should last a whileThat's the stuff that's practically like tar, isn't it?
Originally posted by MattFThe good stuff.That's the stuff that's practically like tar, isn't it?
Originally posted by stormforce1067yep.its used on the track you have special grease pots attached to the rail near to curves to help stop the wheels screeching on the rails as it goes round the curve
now, wondering where all their grease keeps going. Should be some well greased
Surfs knocking about though.
Originally posted by MattFI can just see the railway engineers scratching their heads for the next few weeks
Surfs knocking about though.https://www.facebook.com/groups/henpals/
Originally posted by stormforce1067i will have to find out what sort of grease it is so i can give everything else a good greasing tooIf its a lithium one, it should be the
dogs for all the joints. Last a bit longer than the normal stuff.
