idle up
  • #16
    Ah, you've got a manual gearbox, not so safe with an auto.
    • #17
      Mine's an auto, but I only tried it on a long straight empty road - I don't tend to set it then fall asleep in a slow moving traffic queue!
      Besides, it only raises the rpm a little bit, no where near enough to affect the brakes.
      • #18
        Is there such a thing as an electric Idler that could kick in with a thermostat setting? By that I mean, if the engine or oil temp is below a certain setting, the high-idle will automatically kick in - and then turn itself down when it's gone above that preset value or when disengaged by the driver. ((Maybe I'm getting a little too immaginative here. if I am, someone smack me))
        ie: Cold Canadian winters. Command Start. with and automatic high-idle on a 5spd. (So its actually worth it to have a command start)
        Looking for a 1993 Surf 3.0TD in MB, Canada. HELP!
        • #19
          Most Surfs have an idle-up switch that increases the idle speed by about 500rpm, for faster warm-up and for running electrical accessories such as winches. You press the button once to activate, press again to de-activate.
          On ato transmission modles, it only works in Park or Neutral.
          • #20
            Ya, but not on 5spd's right? they all have the turn button for the idle setting...
            • #21
              No, that's not correct. My 5 speed manual (1995 KZN130) has the push button Idle Up switch same as the auto model I had before.
              Brian
              • #22
                ok thanks, maybe it's just because I had only seen 1991 and earlier models (that's all you can get here in Canada )
