To all you chaps of infinate surf wisdom , i have just noticed a metalic crunching / grating noise and even sometimes a bit of a clunk coming from what i think is the front wheels when manouevering in and out of full lock. It does not happen at any other time , cornering etc and drives really well otherwise. Any ideas as to what it may be and how to fix it would be most appreciated.
Metalic grating noise
Originally posted by ianwoodzieTry Greasing the steering stopps . When the wheel are on full lock there are stops . some have plastic covers to prevent this otherwise when on full lock its metal to metal .
Originally posted by SluggerThanks , i did notice these earlier today when i looked but did not know what these were , and yes the plastic cover on these do seem to be worn so will have a go a greasing these this afternoon when i awakeShould have bought a 3ltr
Originally posted by phoebelalaWow!!!! what was hot plastic doing on your forehead?
I was starting a injection moulding m/c and clearing the waste from the barrel my saftey glasses started to fall off and i brought up my forarm to push them back ,It was on my arm /gloves , i now have a lovley burn above my left eye.....OUCHwww.daemon4x4.org
OK . i have greased the formentioned stops and yes it has certainly made a difference , my next question is - are these plastic caps special in anyway , can they be purchased or can i adapt something or other to make do ?
Originally posted by SluggerOK . i have greased the formentioned stops and yes it has certainly made a difference , my next question is - are these plastic caps special in anyway , can they be purchased or can i adapt something or other to make do ?
I just keep them well greasedwww.daemon4x4.org
