To all you chaps of infinate surf wisdom , i have just noticed a metalic crunching / grating noise and even sometimes a bit of a clunk coming from what i think is the front wheels when manouevering in and out of full lock. It does not happen at any other time , cornering etc and drives really well otherwise. Any ideas as to what it may be and how to fix it would be most appreciated.
Metalic grating noise
Thanks , i did notice these earlier today when i looked but did not know what these were , and yes the plastic cover on these do seem to be worn so will have a go a greasing these this afternoon when i awakeOriginally posted by ianwoodzieTry Greasing the steering stopps . When the wheel are on full lock there are stops . some have plastic covers to prevent this otherwise when on full lock its metal to metal .
03.52 are you sleep typing?Originally posted by SluggerThanks , i did notice these earlier today when i looked but did not know what these were , and yes the plastic cover on these do seem to be worn so will have a go a greasing these this afternoon when i awakeShould have bought a 3ltr
Originally posted by phoebelalaWow!!!! what was hot plastic doing on your forehead?
I was starting a injection moulding m/c and clearing the waste from the barrel my saftey glasses started to fall off and i brought up my forarm to push them back ,It was on my arm /gloves , i now have a lovley burn above my left eye.....OUCHwww.daemon4x4.org
OK . i have greased the formentioned stops and yes it has certainly made a difference , my next question is - are these plastic caps special in anyway , can they be purchased or can i adapt something or other to make do ?
Originally posted by SluggerOK . i have greased the formentioned stops and yes it has certainly made a difference , my next question is - are these plastic caps special in anyway , can they be purchased or can i adapt something or other to make do ?
I just keep them well greasedwww.daemon4x4.org
