Originally posted by ianwoodzie
How many miles in a tank?
Superlift Truespeed... should sort that out.
If its an electronic speedo (and odometer) over size tyres will sqew the readings...? (or have I still not grasped this right...?)
Can't do the maths... but what would the distance be if you caculate the difference between 31" and 33" tyres...?
If you have oversized tyres, you will be going faster than the speedo says.
Originally posted by BUSHWHACKERIf you have oversized tyres, you will be going faster than the speedo says.
Anybody know by what margin? Approx 48km = 30mph, so what difference
would using 33" instead 31" tyres make?
BTW, to the original poster, my mileage sucks as well. I'm sure the people
who quote 25-30 mpg for a 2.4 must be freewheeling down hills.
Matt
I agree matt i cant see how thats possible!Originally posted by MattFAnybody know by what margin? Approx 48km = 30mph, so what difference
MattKite Surf
I have a standard 2.4 with recon engine and turbo, it does 330kms maximum on a full tank, i simply dont believe the claims of 500 odd kms on a tank.
I'm sure my tank is smaller than 57litres.
Is there a fuel light which comes on when you get really low? most i have ever put in is about £40 worth of diesel. and the guage was really low.
If there is a fuel light i might run it till that comes on and see what i get but i dont fancy running out as i dont know how to start a diesel once it's run out.French fishing at it's best www.mayennefishing.com
Yes, there is a low fuel light. Supposedly 2 gallons left, when it comes on. I myself have done a good 30 miles with the light on, but I wouldn't do it everyday!!Originally posted by PauledsI have a standard 2.4 with recon engine and turbo, it does 330kms maximum on a full tank, i simply dont believe the claims of 500 odd kms on a tank.
I seem to remember on here talk of two different sized fuel tanks being fitted to Surfs. 55 and 65 litres, if I remember correctly.
I generally get about 420-450 kms on a tankful, mainly motorway at an indicated 80 (ish)It just does, OK?
