The most i could get with mine was 3800 on the odometer. my tank is a 65ltr one and i filled it right to the top. what would my mpg be? ......
How many miles in a tank?
Originally posted by BETRAYALThe most i could get with mine was 3800 on the odometer. my tank is a 65ltr one and i filled it right to the top. what would my mpg be? ......it's in me shed, mate.
Originally posted by UDTrev3.0 litre and 2.4 about the same for economy - mine get's around 25 to the gallon
Trev9/11 WAS AN INSIDE JOB!
Originally posted by UDTrevEmail me and I will try to sort out a copy of my spreadsheet for you.
Trev
Towing a gross weight of in excess of 2400kg I drop to about 14-17mpg. But as the 2.4td is a bit worn around the piston rings I find it struggles a bit on the hills. Also the Ifor William DP120 has the aero dynamics of a barn door.I am the friend of Hypno-Toad
Originally posted by surfstarMy surf does about 340 Km to the tank, what is that in miles ruffly and is that a bad MPG? If so what could i do to make the MPG better?
What does everyone else's surfs do?Last edited by oohdiddy; 15 February 2006, 22:09.
