Engine removal
    Originally posted by scooby80uk
    Alot more hoses and sensors on a Surf lol
    I would really like to get it running again as i only had it on the road for about a week after i bought it last April
    I dont think im going to give this a go it looks very daunting
      rule of thumb... disconnect everything... lift engine... drop in engine... re-connect everything.
      anyone know if a ford 1.6 CVH fits the same mountings as a 1.6 Zetech?
      just that i can get an RST cheap and i have an oil leak in the zetech that needs engine out anyway... could be fun!
        Matt
        The Escort originally ran the CVH engine so you need the mounts with the engine and it will fit . None of the wirring will be right or airfilter box .It needs to be an EFI RST not the HPI(Bosch) engine or you will have to change fuel pump and fuel tank and fuel pipes to tank . You need all ancillaries , loom etc for it to work .
          Matt
          excellent!... cheers!... seen them with ECU and loom all attatched for £100 (probably nicked, but hey!)
          thought it more fun than putting 1.6 90ps back in!
          p.s. it's a Mk6, so i think only came with zetech.
