Just because the engine is hot doesn't mean the fan is in lock up.
The fan needs to sense hot air at its bi metal sensor to lock up.
The fan will be stiff to turn when you first try to turn it.
After the engine has run for a few mins the oil will be forced out of the clutch rings and into the reservoir
One way to check it is to idle he engine till normal temps are reached
Turn engine off leave for a few mins then try to turn by hand if working ok the fan will be stiffer to turn hence lock up
Putting new oil in is fairly easy search for a how to here
