Well after having a tinkling sound on and off since my last off road jaunt I had convinced myself I had picked up a small stone that had lodged itself in the drivers side front wheel .Off came the wheel so I could get a better look ,had a good root around the inside the disk backplate ,nothing.
Gave the wheel a couple of turns and lo and behold back comes the noise ,yep wear indicator just skimming the disk surface.Disk pads at the limit.
Quick phone call to my local motor factors they have them in stock £22.00 .
Pulled the pads out and was quite alarmed at the ridge on the pads .I am sur the last set of pads came from R/T.
After attending a front hub training session I thought while the wheel is off better have a look at the wheel bearings .
Hub stripped down and was quite surprised at the amount of play I found on the front stub axle about 1.5mm up and down.Other than the tinkling noise from the limit indicator the front end is quiet.Bearings washed and repacked with grease,till I get the time to do the bronze bushes.
Now for the question(s)
Do I whilst changing the wheel bearings and bronze bushes also change the ball joints and outer cv joint boots?
