Ineffective brakes. Advice wanted.
    That is odd, handbrake is exceptional on my old bus and does lock the wheels up. Maybe i`m just lucky, or is rust lighter than solid steel.................
      Originally posted by Fey! View Post
      @Matt; I got the Roughtrax kit because the brakes in my current 3rd gen were cack; the discs were warped.
      Their kit works very well.
      Hope this helps.
      I can second that, in fact all roughtrax components are top notch.
        I swapped out every component on my 2nd gen, calipers, master cylinder, flushed fluid, tested wheel cylinders, adjusted handbrake and shoes, cleaned every part of brake system and still had a crap pedal but good brakes.
        Swapped the LSV but never had a chance to pressure bleed before I sold it. Ali who bought it was getting it done so hopefully all is good now.
        Using the handbrake will keep it adjusted properly provided everything is free to work properly.
        Alan
          If you're stuck, bring your truck round to me; I'll adjust the brakes for you on Monday.
          Thanks for the offer, very kind of you. Are you near to me then?
            Couple of tanks distance?
              I am closer to you and could do them Sat.
              Brian
                I take that as a no then. lol.
                Thanks again for the offer.
                I am more than capable. Its just the finding out what needs to be done that is the problem. Then finding the time to do it.
                  But you have a gammy ankle.
