Originally posted by VidaMusic
View Post
roughtrax first bad experience
Originally posted by VidaMusic View PostI dont think it can be any other way though? the design is in between the caps, not on the side like the old ones, a long nipple would do it, but standard ones, fitted or not, will not fit a normal nozzle in between the caps to press on, you can only just about reach the tip of the nipple (ooeerrr!) before it gets too tight..Brian
Mate, I'm not digging on you but I did wince when you said you fitted them with a press, I wouldn't, you have little control of the pressure used and could easily knock a needle bearing loose or try to press it to far in and break something and bugger things up
Personally I'd have told you not to use a press, but fit next one by hand, but sent you another one anyway.
Sometime I feel a little held to ransom by the internet and do get a little frustrated having to fix things that are blatently user error, but its not worth this sort of post against your name, but thats the price you pay for trading via the internet, but if it happens alot I can see someone getting the hump in the end.
If you can hand on your heart 100% say you could'nt have done anything wrong fitting them then rant away, personally I couldn't. (especially using a press )
I DO have a problem with the current UJ's RT are selling, you can't grease them once installed, but I havn't had a chance to speak to anyone yet.4x4toys.co.uk - Keeping you on and off the road...
Originally posted by TonyN View PostMate, I'm not digging on you but I did wince when you said you fitted them with a press, I wouldn't, you have little control of the pressure used and could easily knock a needle bearing loose or try to press it to far in and break something and bugger things up
i wasnt nasty or even moaning on the phone, i rang up and politely said i was after some advice as it had failed after just 10miles, and before i even finished my sentence he butted in and sternly said "youve fitted it wrong , these are a well known make and DONT just break , ive fitted loads and never had a faulty one so its your fault "
then when i asked if he wanted to see the broken part he basically said no theres no point as it was my fault .
thats whats annoyed me as up until this ive always been happy with roughtrax but with customer service like that its put me off buying from them againPayPal for stickers : scuffsnscrapes@hotmail.com
Originally posted by animal View Postok ive changed the title a bit so doesnt seem so much of a dig at them , just my personal impression and thought about them after today
Anyone can have a bad day, after all.
the only probs i have had when fitting uj,s is when one of the needles falls out and your trying to press on it to fit the circlip, but i go with the fact that the customer is not always right but send him another one for the sake of a couple of quid , and good customer relationsJAP4X4PART ¬ THE BIGGEST SURF BREAKER IN THE UK ¬
Yep, one or more needles falling out is the only thing I've ever had problems with in the past. Using a vice or clamp to re-assemble the joint will show this up very quickly.
What did you use, in the press, as a jig?Do you know that, with a 50 character limit, it's
Cheers, Nick"The force will be with you, always!"
Hi Chaps just thought I'd better follow up on the posts being made.
I'm not going to get in a big heated debate over whom said what other than that not all what’s been depicted is entirely correct and as said.
Yes its true I have fitted hundreds of these UJ's to all makes and models, and I do strongly believe that on this occasion to crack out the end of a case hardened UJ cap can only be done by in my opinion dropping or cracking a needle roller upon assembly or some form of contaminant entering the cap, especially when I was initially told that on assembly using the "press" it snatched as the caps where assembled, or words to that effect. A UJ end cap won’t just break out unless excessive force has been applied in some form or fashion and once driven would then cause failure.
My words on fitting were that caps are an interference fit within the flanges, not pop in.
UJ's should always be checked after fitment for smoothness in either operating plain or if tight, rectified, never forced.
Fitting of some components isn’t as always as it seems and some parts take trained experience. Failure of a part isn’t always down to the part fitted, infact more often not and a reason for the initial failure should also always be checked out and not just assumed that its that part causing an issue, this is true with any repair. Warranty will only cover a defective part, not if caused by incorrect fitment or another force causing that failure.
As many customers know we always honour our warranties and will always continue to do so, but we won’t, indeed cant as a company, honour parts failure that’s not down to the part no matter how large or small.
Should the customer wish to call me and discuss it further with the findings from the prop shaft company that fitted the new UJ then I’m happy to listen.
Regards
Barry
RoughTrax
What a load of bollox
I didn't say it snatched when fitting at all.
It was checked after fitting and was smooth
And as for the bit about only offering warranty if a part is found to be faulty , you weren't even interested in looking at the old part your answer was that it was obviously fitted wrong.
I just collected my prop which has been fully refurbished and has a uj fitted which has a nipple that's fully accessible when fitted . So no if your going to come on here calling me a liar then I'm not interested in calling you to discus at all . I notice you didn't comment about other people having issues with the positioning of the grease nipple etc as this is obviously a problem .
I was changing my mind about using roughtrax again but after reading this post I've be swayed the other way again
So comment all you like to make yourself look better as we both know the truth about what was said in the phone conversation don't we!
End of conversation . End of dealings with roughtrax!
ByePayPal for stickers : scuffsnscrapes@hotmail.com
Arguments about who said what aside,I can't see how a UJ can possibily break a cap in use? It just can't happen, the forces are all wrong, it MUST have been broken before or during installation, a snap ring wasn't fitted correctly and it worked its way out or the prop is damaged where they fit.
Something needs to move to break or crack, and it dosn't move once fitted, the needle rollers just roll around inside it, they don't even move that far
Even the most mullered UJ with no bearings left and worn yoke dosn't break a cap, just wears it away.
Confused....
(edit....just re-read this, not being harsh or a dig at you, but if I'd had this problem I'd assume it was my fault fitting it bady, as thats the logical answer to what happened.)4x4toys.co.uk - Keeping you on and off the road...
