Originally posted by Bogus
View Post
torsion bar adjustment
Originally posted by tintin View PostWithout lifting the front wheels that bolt is under enormous tension, when it snapped he couldn't find one end, until he opened his truck and found a hole in the floor and the end of said bolt embedded in the underside of the seat!!
AlanCutting steps in the roof of the world
I've done the torsion bars on my truck and much over 2" will make the wishbones sit on the top-stoppers and give a terrible ride, I counted quarter turns, dropped the truck back down and bounced it then measured wheel rim to arch on both sides and repeated a few times till it sat right... then drove it a few miles and re-did it again.
I jacked it up on the centre cross member, on perfectly flat concrete when I did this, slanted drive... not good.
peace
calBala Mud, best underseal there is, only £30 per application.
www.thecellardwellers.co.uk
I'm pleased to see you're taking the truck to a pro get it sorted. Don't lift the front by more than 2" over standard or you'll go through CV boots/joints faster than you can get it booked in for repairs!
Free-wheeling hubs are a good idea to reduce CV wear. Simply disengage them for normal road use around town, etc and engage them when you're off-roading.
I bought and fitted these ones (it's an absolute doddle and shouldn't take your garage mechanic more than half an hour or so to fit) from Roughtrax:
http://www.roughtrax4x4.com/?doc=16&cid=146&vid=1139
If you want to go more than 2" to level up the 3" at the rear (which, if I remember correctly, is what you have done with Land Cruiser springs...) you would probably be best advised to get a diff drop kit fitted like this:
http://www.4crawler.com/4x4/ForSale/DiffDrop.shtml
Do a bit of searching around the site and you should get all of the information you need to pass on to your mechanic.
(Note: I am no expert but this is the info I have gathered from doing various searches on this and other sites myself over the last year or two)
Originally posted by yoshie View PostThe 1.5" ball joint spacers let you keep the height and wind the bars back to normal setting. Makes the ride and movement off and on road so much better.
Well worth fitting.
sound and i got free wheel hub's to go on thats my next job. Can't believe i got my surf 6 moth's ago just to sell on and make some money on. fell in love with it within a week and now dont think i will ever sell her.http://www.mudmuppet.com
Well worth fitting.www.vidamusic.co.uk
Yes, if you're changing balljoints, its a good time to do the spacers.
As Yoshie said, they give you the OEM ride quality and the height increase. Whereas winding up the bars just gives you height and ruins the flex / ride quality.
Deffo recommend them. I think Surfenstein manufactures them too.Cutting steps in the roof of the world
Originally posted by Apache View PostYes, if you're changing balljoints, its a good time to do the spacers.
My missus's Pickup has the bars wound right up and the ride is terrible, I think it's on the bumpstops.
So BJ spacers will improve the ride quality as well?
Sent from the iPad you "lost"
