Why does it do this!!!!!!!
  • Why does it do this!!!!!!!
    ok,my surf,if i leave it 1-2 days without using it,it wont start,turns for a bit till it dies,the 2 other surfs i had did the same thing,does yours do this and why do they do it,my batterys are new so cant see it being them.
    Sounds like a fuelling problem. Pump / primer leaking?
      iam having the same crap with the die hat sue sportrak
        I never use mine Monday to Friday so can be parked up anywhere between 4 or 5 days to sometimes a couple of working weeks.
        Youl need to determine what is lacking for the truck to start. As Sancho said it could be a fuel problem. Providing there is fuel and the glow plugs have heated then starting shouldnt be a serious problem like that.
        Have you tried using the mechanical primer button before cranking to see if that helped? Press the button a good few times, the button should get stiff to press as far as I know (prividing it works correctly!)
        Oh Nana, what's my name?
          when mine had new batteries i could go on holiday for a month and it always started first time, the batteries are 5 years old now and still last 2 weeks.
          fuel problem or glow plugs like diesel boy said - cant be much else on a diesel motor unless its very tired - im assuming it goes fine if it starts.
            just an extra thought - have you checked the electrics with a meter to make sure you dont have a current drain when its switched off - you could be trying to start it with drained batteries - also check the earth straps( all of them, batt engine etc.)
              thanks for all the advice guys,il have a look at these things 2moz,if i use the truck every day its fine,but left for a bit wont start,its an annoying problem,my battery connection are very very dirty,il give these a good clean too.
                yeah could be leaking,its foookin bad on diesel
                  out of them id say fuel problem because the glowplugs are fairly new
                    hi just out of interest my friend at work (webbo) had the same problem bad starting and somtimes not at all he had new batteries checked the glow plugs all ok then found out it was the 80amp fuse that is also connected to the cig lighter. dash heater light came on as normal but i guess the heater plugs were not getting the full amount of power. he put a new fuse in complements from a fellow member and hey presto not a problem since.
                    just check your cig lighter is working this might be your problem
                    surfs just steal all ya money
                      Even with a dodgy 80A fuse, the truck will still start. Do as Gary said and check for current drain, that's the only thing that will flatten new batteries in 2 days.
                        Just a thought, you say you have 3 Surfs that all do this? Are there any common accessories between the 3 of them? Or any mods that you've done to all 3?
                          Sorry, just to make it clear (as Albannach and I are answering two different questions), when you say 'it turns for a bit then it dies', do you mean that it is turning over as normal and not firing, until eventually you run the battery down or do you mean that it only turns over for a short period of time?
                            have you sorted the amp out cos that was n all the time b4 you put the double din in or it mite just be you you was looking for a reason to have a go in mine again lol how many time's it jump started your now lol ........ didn't the bat's go flat the other day when you was cleaning it as well or was that the old one's
                            http://www.mudmuppet.com
                              i dont have 3 now,just the one but the 2 ive had before did the same thing,only thing they have the same is an alarm,thats all i can think off
