help. need antifreeze
    Originally posted by soramad View Post
    Erode - to wear away / destroy gradually
    Corrode - to rust / to eat away at / erode
    Taken from the Chambers Dictionary
    That may be what the Chambers dictionary says, but most peoples understanding of corrosion and erosion are vastly different. Erosion is a purely mechanical action. Corrosion is a chemical reaction, so there,
    Bogus
    Сви можемо
      Bogus
      no its not.
      Non intercooled nothing.
        Does it go below in Cornwall?
        Sent from the iPad you "lost"
          everything is below in Cornwall
            no its not.
            Is to me..
            Erosion means Grand Canyon, glacial valleys, etc.. Corrosion means rust, crunchy coolant hoses and seized bolts.
            But then we're not all as brainy as you and like to make life simple, not complicated.
              Is to me..
              I'm not brainy...I do poo and hummers...what's brainy about that...bleedin daft if you ask me.
                thanks all
                thanks for all your help guys!! will fill it with 50/50 red on tuesday. silly me, didn't think of the corrosion when i filled it with water :-s hopefully not too much damage done!! thanks again
                  What do you mean by " 50/50 Red "
                  You've just been told not to "use water" and that it goes in "neat"
                  • #24
                    if you use toyota ready mixed red coolant do NOT mix it with water it goes in neat.
                    and to tonyn corrosion is due to moisture or acid/fumes attacking exposed steel/alloys , erosion is usually caused by movement of liquid ie a river running through a field or coolant fluid being pumped round an engine.
                    • #25
                      No $hit......
                      and kinda exactly like I posted then?
                      • #26
                        No $hit......
                        • #27
                          But it's not.
