Originally posted by Apache
View Post
Set hinges at about 8 inches from top and 10 from bottom - reduces the optical illusion of bottom hinge looking like its lower than it is.
cut around hinge with stanley knife to create recess and cut out with chisel.
screw hinges to door.
offer door up, mark hinge locations. take one off and mark up frame, using stanley again. depth of hinge hole should be same as the hinge.
screw door up to frame. and hopefully it will shut, if not, fettle the hinge holes BEFORE planing anymore off the door!!!
Fit door furniture. Remove door furniture, remove door and hinges, seal and paint/varnish door and frame. refit everything.
Simples.
