how much boost :S
    thanks guy's will get it on soon as i can cos it mug's me every time it see's a fuel pump
    http://www.mudmuppet.com
      In fact im wrong andy,i have just read 10.5 psi before going limp.
      www.overfab.uk
        More boost aint gonna use LESS fuel you know?
          Originally posted by lukenemma View Post
          let me know when there ready i'll have them
          Shall do.
            so i've maxed out the boost alread dose any one no if i can get the thig remapped ??? and yes i no that will kill off the 50k warrenty on the engine but i think the intercooler will do that any way
              Intercooler, more boost, remapped ECU, higher fuel bill... more heat into an already inadequate cooling system, so bigger radiator, better fans...
              Just buy a 3.0 and have done with it!
              By the way, I very much doubt the ECU will be remappable. It's pretty ancient technology. If you're going to do it properly, you'll probably want a configurable gearbox ECU too for 'harder' changes or all you're gonna do is heat up the torque converter more.
              In short, you're not going to get worthwhile increases without spending. Its not renowned for being a tuneable engine.
                didn't think it would be remapable and think i'll just put the cooler on as already got it and put the rest of the money into the v8 pot for way down the line
                  Much more sensible.
                  • #24
                    how much boost can i fun on my 2.4td it has a new ish turbo and the engine has done 17000km (was a recon still underwarrenty) the heads uprated and i'm going to be fitting a shogun intercooler with a bonnet vent soon as i get the chance and dose any one no how much inprovement this will make to the preformance i'm running 10psi right now
                    Depends on how much fuel you can put in, the temperature of your exhaust gasses, and what you have done to fool the ECU.
                    Oh Nana, what's my name?
                    • #25
                      well can i do it on the cheap as saving for a v8 (seen it on here 2k all in) and with out trashing me engine as it aint been in the surf very long and the bloke b4 me spent shit loads on the thing
                      • #26
                        coss she aint very quick right now
                        That's because the only way to ever get a 2.4 to go quick is down hill. The steeper the gradient the better.
                        If you want really quick use a cliff.
                        Gone from 4x4 to 1x2
                        • #27
                          So you're looking for better fuel economy and want to fit a V8? It doesn't add up mate.
                          • #28
                            Can you get loads of power from a 2.4 without spending money, whilst getting more mpg and without blowing it up?
                            NO!!!!
                            There.
                            • #29
                              i'll not be woryed about economy when i get a v8 (some day) just need to save money so i can get a v8 and it's alot better now it's running 10.5psi you can feel the diffrence and it'll do for now till i got 2k for the v8
                              • #30
                                best to have this on
                                http://www.youtube.com/watch?v=ti-Yh...eature=related
