torque converter
  • torque converter
    hi need help think my torque converter is leaking had it looked at mac says thats what it is. there is oil coming out where gearbox meets engine. red- brown in colour. Where can you get new one and how much would this cost?
    Torque converters don't leak, they're a sealed unit.
    It's most likely the transmission oil seal thats worn. either way, the transmission needs to come off.
      thanks how much do they cost just in case thanks.
        Torque converters? A couple of hundred pounds I would have thought, never had cause to look for new ones to be honest.
        Oil seal? About £8 if it's a dealer part.
          Vince is right, it 99.99999999999% will be the seal.
          Parts cheap as chips, but lots labour if you're paying someone to fix it.
            yes paying for it as i only no the front from the back £60 per hour 2 days they say
              recon ya torque converter 185 with vat
              new torque converter 285 after market one
              toyota was over 400 quid if i remember rightly
                2 days @ £60 an hour..? nearly £1K???? assuming an 8 hour day, I hope they mena they want it for 2 days, not working on it for 2 days!!
                Shame you're so far away, I charge £200 to remove and replace Surf gearboxes and still feel guilty.
                  Probably worth the drive for that price!!
                    seen one in scrap yard but its of h reg will that be different . by the way it would be cheaper to come down and stay in bed breakfast thanks
                      this is the first 3rd gen i have heard with this problem.I would drive down to Tony and save a few hundred ££'s and have him sort it for you
                        So you're convinced it's the torque converter then?
                          iam not and i have blow my whole gearbox before
                          sounds like the seal and you dont want that to leak dry
                          like mine did
                            no not convinced but there is one in scrap yard gearbox and torque converter if not to much £££££££ mite bye but this is of h reg will it fit would like to have parts as its 410 miles super glue my eyelids up to get there.....your all very helpful thanks
                              but this is of h reg will it fit.....
                              nope. gearbox is very different, so would probably guess the convertor is as well
