Originally posted by blackpoolsparks
View Post
Originally posted by Albannach
View Post
You can press the 4wd button on the move at low speed.
You must top and select neutral to engage the 4wd locked high or low options on the transfer box selector {small gear stick}
You can also select H2wd, H4wd, H4wd locked, L4wd locked
DONT DRIVE on the road with the centre diff locked i.e the small gear stick in 4wd locked position.
The selector for you i.e 2nd gen driver is on the wrong side
Glad you have seen the light.
