Hi Matt
I filled it up then took the heater pipe off and put the hose on until water came out of the heater pipe also the filler.
Did a short run and all seemed OK but when parked it I could hear bubbling in the expansion tank, some water ended up in the tank but it didnt overflow, so I went for a longer run (about 2 miles) thro the village, the temp went to hot.
I limped home and left it for an hour and checked and there didnt seem to be any water left.
I refilled and started it with the filler off and there was a constant flow of air bubbles. I parked it up and left it, when I started it this afternoon, it having been left all night, I took the filler cap off almost as soon as I started it and WHOOOSH loads of water shot out.
It apparently had a new head fitted about a year ago (supplied by Milners and fitted by a garage in Anglesea) but it would pressurise the water from then on.
When I took the head of there was evidence of blowing into about three waterways, but no serious damage. So I fitted a new head gasket, I did have to get a longer head bolt cuz the thread pulled out of the block (bolt 12 I think).
I had high hopes for this... but now?????
